Status
Not open for further replies.
1 - 3 of 3 Posts
I pretty sure I am on the way to having the pj setup after the new tubes.
Is there anoughter way to set eletronic focus? While looking at the blue crt I have to turn the fucus pot all the way clock wise to have good eletronic focus. I would like for it to be in the middle.
I have setup the red and green and they work nice, only stuck on the blue.
I have acouple of the service manuals and setup sheets but doesn't say anything about it.
Thanks agian
Brian
Try swapping the focus leads between tubes at the bottom of that focus block. That will let you know if it's a bad block or a bad socket/blue tube.
Curt
Discussion Starter · #3 ·
Good idea I'll try that, I even have anoughter focus block from a 1251q pj. For some reason I thought that I read some were that there are focusing magnets on the tube.(Not the agist ones) I still get good focus out of the blue but like I said the pot is cranked all the way.
Thanks for the input
Brian
1 - 3 of 3 Posts
Status
