I have another question about my newly acquired Sony 1031 (my first CRT). I have been spending most of my weekend working with this projector, trying to get a better image out of it. Now I am starting to wonder if I have the wrong shims installed on my projector. I have found that the rings are aligned for 100" projection, which should be right for me since I am using a 45"x80" screen (right?). I have set the projector 129" from the screen (lens to screen) as instructed in the installation manual. The problem I am having is that the Blue will not focus on the left side and the Red will not focus on the right side. The center will focus fine on both.
The projector did not come with extra shims. I am not sure which shims are installed but from description at ********* dot com ("Looking at the thickness of the shim from the top, the large are approx 1/4" thick, the medium are approx 1/2" thick and the small shims are approx. 3/4" thick") it sounds like I have the large set installed. They are around 1/4" thick at their thickest and narrower toward the center of the projector.
I have happily determined that the lenses on this projector are HD-6.
Please excuse my novice description and question, but I am trying to determine if this projector is set-up correctly before I spend any more time trying to focus it. Thanks in advance!
-Mark
-Mark
