Status
Not open for further replies.
1 - 6 of 6 Posts
Hey Guys, I've just about had it searching, will jump on either of these (Bronze2 or 601s3) this wk. the prices are very close, both sound good (B&w a little warmer, I like brighter) but wanted your takes. I also am considering getting a 3rd one instead of a CC as it would fit better on my TV unit.
BTW, thanks for helping out a noob!
I fully support using an identical center....IMO it is actually superior to using a traditional center. Two good choices of speakers...you will enjoy either ones.
I've listened to the entire line of 600's.
Not bad sounding, but slightly boxy and darker when compared to the CDM line of B&W.
A/B testing between the 602's and the CDM 1's is was easy to see that the CDM was superior. Clarity, more defined highs and lows.
I've seen the CDM 1NT's was for a little as $750 as dealer demos and $700 on audiogon.
I personally didn't like the 600's.
You really need to go listen for yourself.
1 - 6 of 6 Posts
Status
