Status
Not open for further replies.
1 - 6 of 6 Posts
uhmmm holy wavey batman!!!!!
Are you using a really bad screen or is that the wall?
Converging these ones is not difficult so i would assume that your projector to screen setup is not straight. Get some string and attach it to the left hand side of the pj's case at the front do the same to the right, Now run the string from the left side of the pj to the midpoint lefthand side of the screen and do the same to the right side-now are these 2 strings the same distance? Is your projector level? If you don't have these things looked after first then convergence is a nightmare.
cheers
Wayne
Discussion Starter · #4 ·
Thanks Wayne,
Lol thats a Sheet, nice screen lol. I will soon be replacing that with something hopefully better!!!
I will try the method you suggest as it's probably not aligned perfectly. I will post later if that works or not.
Thanks a million
Jimmy
Discussion Starter · #5 ·
Finally got it down!!! After playing around I finally adjusted the lenses one by one turning off the other 2 colors while adjusting one and got the picture focused!!! Can't wait till tonight when the sun goes down to watch a few movies!!!!!
1 - 6 of 6 Posts
Status
