I just received the Audio Authority Autoswitching box from Digital Connection. It's working great! It accepts 4 inputs (either SPDIF or Toslink) and outputs to 1 SPDIF or Toslink. I decided to go this route as I had two SPDIF outputs (Audiophile 24/96 and MyHD card) and did not want to have to manually change configurations when I changed my source (either two inputs into my Denon receiver, or output from MyHD card into Audiophile, and then changing config in M Audio setup).
The box automatically detects which input is active and switches accordingly. The user can also manually select which input to pass through.
I highly recommend this unit if your WAF is low, or you're just lazy like me
Darryl
Darryl
