I downloaded this and updated my 2910 firmware with it. Its played two Region 2 discs fine so far. Microcosmos is a great Region 2 dvd if you can find a copy.
2910 Region Free Firmare
3910 Region Free Firmware
It recogized the cd , loaded, and flashed from reading, writing and erasing for about 30 seconds. Then I powered cycled it to load the new firmware. Woooo hoooo! Its seems to be region free now. Though I have no idea what modded version of firmware this it. I took a risk and did it anyway.
Hopefully its a modded version of the current firmware. It came from a french page, in the bottom paragraph, whose internet translation of French to English is :
The french page is here, the above firmware links are at the bottom
I make small a r�cap on the d�zonnage of these machines: For d�zonner, it is enough to: 1 to download the firmware corresponding to its reader, 2 the d�zipper 3 to engrave it with Nero (without particular adjustment) 4 to insert CD engraved in reader 5 to let the reader rewrite the firmware (writing) 6 to await jusqu'� automatic l'ouverture of drawer 7 to extinguish the reader (not with the button stand by, l'�teindre completely) 8 to relight it... it is from now on multizone, RCE included/understood. This manipulation went for my 2910. However, one finds a manipulation more complete. Jusqu'� 7 nothing changes. But from the 8 that changes: 8 to relight the reader and to close the drawer. 9 to support and maintain to support the button Play, and Forward Skip and Open during more than 3 seconds jusqu'� what "Initialized" s'affiche.
Can anyone make sense of the rest of the instructions after the first part. It sounds like a description of a number sequence on the remote control possibly?
Anyone have any idea of how to check what version the firmware is that these units ship with? and the remote codes or button sequences to discover this stuff?
Credit for the firmware discovery on that link goes to user arioch on here.
I found it at the french page he listed in a post but no one apparently had tested yet so I thought I would test it as I want a region free player and share the results with fellow avs members.
Since I know absolutely nothing about it, try it at your own risk.
The 2910 is wired for component on a large tube tv at the moment, not DVI, but all the main setup menus and options appear identical to my eye so far.
