Status
Not open for further replies.
1 - 1 of 1 Posts
Well, I never could get my optical SPDIF on my Shuttle XPC Sk41G to work with my receiver, so I went to work on getting the ATI AIW Radeon coax SPDIF to work. Well, I got it working, but the problem is, the sound is out of sync!
When I say out of sync, I need to double check, but I believe the audio is actually about two seconds too early. Does this make sense, or could I just be wrong, and the audio is delayed? Anyways, it is definitely out of sync.
Has anyone had a similar problem with an ATI product, and if so, how do it get solved? This is definitely more difficult than I thought it would be.
ATI software is:
7.7MMC using the latest Catlyst driver for the AIW Radeon 32MB.
I also am using the 7.7 version of ATI's DVD player, with the audio output setup to go directly through the ATI Rage Theater (SPDIF on dongle) so that is how I got digital to my receiver to work.
I output to Akai Plasma via the RGB running a 848x480 desktop.
HTPC is Shuttle SK41G with XP2200+, 512MB DDR, Maxtor ATA133 40GB, and an older UDMA33 6X DVD ROM drive.
1 - 1 of 1 Posts
Status
