Four JBL 322CT's 12" w/1.5" Compression Drivers (Kevlar-reinforced cone)
JBL 322CT and be wired in any room or in series - They are amazingly clean and clear with "zero" brightness. Also, they offer a full range from
Frequency Range (-10 dB)1: 32 Hz – 20 kHz with plenty of punch!!!
/w Enclosures ($300 each) and Grills...perfect for L-C-R or Surround speakers sonically matched with JBL Synthesis SCL-2's ($6K each), as well as K2-3300's ($ 11K each) due to these JBL DNA/Build Quality - They, are also perfect "Wide" speakers due to their pattern
Low-Frequency Driver: 12"
Kevlar-reinforced cone, 75 mm (3 in) voice coil.
High-Frequency Driver: JBL 2407H neodymium-magnet medium-format
compression driver with 37 mm (1.5 in) diaphragm
Specifications:
Frequency Range (-10 dB)1 :
32 Hz – 20 kHz
Coverage Pattern: 90° conical, broadband
Power Rating: 400W (1600 W peak)
Paid $3800 - Sell for $2400 + PP fee for all four - Pick up preferred but will consider shipping(factory boxes) - Fair Offers Welcome
IM me with all of your questions...
Directivity Factor (Q): 9 (1k - 16kHz) Directivity Index (DI): 9.5dB (1k - 16kHz) Long-Term System Power Rating, IEC3 : 400 W (1600 W peak), 2 hrs 250 W (1000 W peak), 100 hrs Sensitivity (
[email protected] 1m): 95 dB4 measured half-space 100 dB5 computed for competitive comparison Maximum SPL6 : 121 dB cont ave (124 dB peak) Crossover Network: 1.4 kHz, 3rd order (18 dB/oct) high-pass plus conjugate to HF, 2nd order low-pass to LF. Nominal Impedance (322C): 8 ohms Transformer Taps (322CT): 70V: 100W, 50W, 25W, & 12.5W 100V: 100W, 50W & 25W Transformer Insertion Loss (CT): 1.0 dB typ. Transducers: Low Frequency Driver: Kevlar reinforced cone, 75 mm (3 in) voice coil. High Frequency Driver: JBL 2407H neodymium-magnet medium-format compression driver with 37 mm (1.5 in) diaphragm. Physical: Input Connector (322C): Removable locking connector with screw-down terminals. Max wire 12 AWG (2.5 mm2 ) 322C: 1) + in, 2) + loop out, 3) – loop out, 4) – in Tap Connection (322CT): 322CT: A) Common B)
[email protected],
[email protected] C)
[email protected],
[email protected] D)
[email protected],
[email protected] E)
[email protected], n/
[email protected] Safety Agency Rating: Suitable for use in air handling spaces per UL1480, UL2043, NFPA90 & NFPA 70 when installed with UL listed backcan such as JBL MTC-300BB12. S7232/UL Listed, Signaling Speaker. Transformer UL registered per UL1876. In accordance with IEC60849/EN60849. Baffle: Metal, 366 x 366 mm (14.4 x 14.4 in), driver pre-mounted to baffle, ported, EZRail™ for easier installation to backbox. Baffle Attachment to Attach via either 4 corner holes M4 x 14 mm MTC-300BB12 Backbox: machine screws, or 6 side/end holes #10 x .75 in (19 mm) sheet metal screws. Grille Attachment to Baffle: 4 pcs 4 mm machine screws in corners. Dimensions (H x W x D): 366 x 366 mm (14.4 x 14.4 in) square baffle x depth from back of baffle of 223 mm (8.8 in) on 322C & 240 mm (9.5 in) on 322CT. Net Weight: 322C: 20.0 lbs (9.1 kg) 322CT: 22.0 lbs (10.0 kg) Shipping Weight: 322C: 23.4 lbs (10.6 kg) 322CT: 25.8 lbs (11.7 kg) Included Accessories: Ported baffle pre-attached, transformer on 322CT. Optional Accessories: MTC-300SG12 Grille, square contoured, white. MTC-300BB12 Backbox, 80 liters (3 cubic feet) MTC-300T150 Transformer, 150 W for use with 322C
