Got a new JVC DLA-X55 projector , the guy who installed it says despite what i think that the bulb problem is only in the older bulb type projector and that a ups is not need even if there is a sudden power outage nothing will happen to the projector.
i live in india where there are frequent power outage and have a backup diesel generator which comes online in case of a power failure in 5 seconds.
As far as my understanding goes with frequent powercuts, and switching off the projector without a proper shutdown reduces the lamp life, Please advice
http://procision.jvc.com/product.jsp?modelId=MODL029154&pathId=71&page=10
http://www.avforums.com/review/jvc-x55-dila-projector-review.431
jvc.jpg 323k .jpg file
As per the manual
Turn off the power
Remote control: press the (D [STAND BY] button
Projector unit: press the £')/ I [STAND BY/ON] button
° While the “Are you sure you want to turn off?” message is displayed, press the button again.
° The lamp turns off, and the “STANDBY/ON” indicator switches from a green light to a red blinking light.
° After the light goes off, the fan will run for about 60 seconds to cool down the lamp (Cool-down mode)
Do not disconnect the power cable while cooling is in progress.
° After about 60 seconds, the “STAND BY/ON” indicator switches from a blinking red to a solid red light.
“STAND BY/ON” blinking (red) “STAND BY/ON” lights up (red)
In the Cool-down mode In standby state
CAUTION
° The power cannot be turned off within approximately 90 seconds after it has been turned on.
° The power cannot be turned on again while cooling is in progress (60 seconds).
° Pull out the power plug when the unit is not to be used for a prolonged period of time.
