1 - 1 of 1 Posts
hello dear all,
I am from india
Here we have houses with brick-concrete type construction mostly.
Was planning to do suspended ceiling for my room size 13.5' lengthx10' widthx10'height, with:
Grid ceiling system: Featuring grid acoustic mineral fibre ceiling panels 2'x2' + steel T-grid.
Main concerns:-
(1)Vibration:- would the above ceiling have vibration of the grid at high dynamic low/mid/high freq. sounds or high volume levels?If yes whats the solution then.
(2)Can i put insulation rolls above the ceiling, for sound attenuation?
Or
I should adopt some other ceiling solution like the drywall suspended ceiling with metal framing system.would this be better than the above.
Thanks in advance, i need your advise urgently plz
1 - 1 of 1 Posts
