1 - 5 of 5 Posts
· Registered
I am thinking about having a powered Curtain system covering my screen. If I do that, I would want to place all my speakers in a fabric covered frame below the bottom of the screen height. How different is it acoustically to place the Left, Right, & Center speakers below the screen and aim up towards the listening position versus placing the Left & Right speakers at ear level and having the Center speaker below the screen and facing towards the listening position?
Matt
· Banned
It is a general rule that speaker placement should be put at ear level or even better, slightly above. If in your case you are placing them bellow ear level this way, I would not recommend it. Why do you want the curtain to go all the way across the front wall?
· Registered
Discussion Starter · #5 ·
Thanks for your replies. I'm unable to sacrifice the depth to place the speakers behind the screen. I really wish I could do that. I only want the curtains to cover the screen then open and go behind a narrow false wall or column on the sides. They do not need to cover the entire front wall.
Matt
1 - 5 of 5 Posts
