The power LED header on my motherboard has 3 pins in a row - 1 positive, and 2 negative (in positive, negative, negative order). My case came with a single positive one-pin power LED connector, and a single negative one-pin power LED connector, intertwined, but separate.
My question: Which negative power LED header pin should I connect the sole single-pin negative power LED connector? The one directly next to the positive pin, or the one with a negative pin in between it and the positive pin?
d'ler
d'ler
