Status
Not open for further replies.
1 - 2 of 2 Posts
I know there are dozens of threads about this case, but I want some specific informtion about disassembly.
Just got my ATC600 two days ago, and I want to illuminate the front plexi.
what I want to do is intriduce some light on either side, so that when closed, the plexi glows. I have the concept down, but before I start tearing apart a $200 case, I want to know from those who have had it awhile.
To either side of the display, are two "chunks" of aluminum about 1.5" wide by the height of the plexi. This is where I want to introduce the light. They appear to be removable. But how? Do I have to remove the entire front fascia and then there are hidden screws? The "seam" appears to be more than just "etched" so that is what makes me think they remove.
Anyone gotten the case apart far enough to know? If so, how do they come off?
Discussion Starter · #2 ·
Did anyone else ever get one of these babies apart? I still want the affect, but I'm still scared to start taking things apart. ANyone have any thoughts on how to get the plexi and the side panels off? I know there were some people talking about replacing the plexi with a different shade/color...any luck?
1 - 2 of 2 Posts
Status
