I have all my equipment setup in a cabinet wall unit. I was running new 24guage hdmi cables some to my receiver. After I finished i noticed my front left speaker was not producing sound. This happened once or twice when i previously ran cable if i pull to hard and its tangled the connection will come out usually i noticed the back ends were simply not screwed in tight so i check them every few weeks to make sure their tight, but it always works again when i reconnect, this of course is purely an accident and does not happen very often. Well this time my connections did not seem to come out but i did loose sound.
Then trying to reconnect it, my right side lost sound to.
All other center, sub, backs, surround backs, work fine. I narrowed down the problem to my the connections on the receiver. At first I thought i might have wrecked the cable but then i tried the cable on the center channel and it worked, i also swapped speakers out to make sure it was not the speaker.
The only problem it can be is the connector on the receiver itself. Do i have any options to try to fix this, should i pull it out and make sure the connectors are clean? Im really out of ideas, i have no idea why the connector themselves would stop working, although i dont have much knowledge of audio.
Any advice or tips would be much appreciated.
