Does anyone know the secret (trick) to removing the whole front screen assembly (the one that is bolted to the front of the tv on the bottom)??? When I have removed all the bolts I still can't lift up on the assembly to remove it. It seems stuck in some way. I have removed all bolts and trim from the front. It seems as if the whole unit should just lift right off. Is there a special area to lift up on or way to do this???
I know I have to unplug the magic focus plugs from the back of the tv because they are connected to the front end unit.
Any help would be appreciated!!!
