Luxman 507uXii | Klipsch Forte III | Stereo Rel T7i | 77" LG G1 | Lumin U1 Mini | Denafrips Pontus I
I'm going to start working on my finished basement (eventually), and I'm not sure how I should go about treating the front wall. Should I:
apply OC701/703 to the entire front wall and build the FP screen in front of that.
or,
frame in a new wall, insulate it and cover with fabric, as well as incorporate the FP screen.
I think the second option will work well, and probably look better in the end.
I'm also going to be installing laminate flooring over top of dricore and building a seating riser. I'll also be trying to build in some corner traps and other treatments - although i'm limited for space.
Anybody with any experience on a similar project, tips, warnings etc. would be very helpful.
or,
