I don't know about un-Maclike but that behavior is designed to give a use a custom slideshow feel without having to set up the slideshow to begin with.
However, here are some workarounds:
1) You can select a remote album in iPhoto and set the desired music you want played back when viewing that album. This can be a song or playlist.
2) You can manually create your own slideshows in iPhoto and determine your own transition effects and turn on/off Ken Burns Effect.
Hope that helps.
Kevin
Hope that helps.
Kevin
