1 - 2 of 2 Posts
Ascend Acoustics Sierra 2EX's + Duo, GSG 18" Marty Cubes, Arcam 550, QSC DCA, Sony 65X900F
My video setup for context: Apple TV 4k -> Arcam AVR 550 -(Arc)> Sony X900f
I use the Apple TV 4k remote for everything and when the Marantz was connected, it worked flawlessly.
The problem: Intermittently when turning down the volume, it switches from the Arcam volume to the TV volume but the TV shows it's already at 0 and won't go down anymore. I can them turn the volume back up and the Arcam volume goes up. If I try to turn it down again, it will switch again to the TV after an arbitrary number of DB's and again switch to the TV volume and it shows 0. It's not a fixed number on the Arcam volume that it reaches and switches to the TV. It changes every time but it is around 4-5db before the switch happens.
Any ideas?
Turn off CEC control between TV and AVR, do it on the TV side.
I am not taking consideration to any other connection/sources u may have since you haven't disclose that info, if any.
1 - 2 of 2 Posts
