1 - 1 of 1 Posts
Complete Audio Design Associates (ADA) home theater/theatre system featuring Suite 7.1HD pre-amp/processor (HDMI 1.3), TEQ-8 Trinnov active room equalization system, and PTM-8100BAB power amplifier (the BAB version features a blank front plate - NO meters).
ASKING: $10,000CAD
All accessories included: ISO-CAT II ADA Bus, Trinnov microphone and ADA IR remote control (not pictured).
Does NOT include original boxes or manuals (hard copy manuals weren't included at time of purchase, but PDFs will be provided as downloaded from ADA). Shipping costs are NOT included, and will be charged at courier cost (including insurance) without markup. Shipping within Canada ONLY. Optional pickup available, or FREE local delivery in Ottawa/Gatineau, Canada. Please enquire about delivery options for the U.S.
SUITE 7.1 HD
  • Dolby TrueHD & DTS HD Master Audio
  • Multi-Channel (192KHz/24 Bit) PCM Audio
  • Full 7.1 EX/ES, THX Ultra 2, Dolby Pro Logic IIx, DTS Neo 6
  • 8 HDMI Inputs with HDMI Equalization Settings per input
  • 2 (Dual) Mirror HDMI Outputs with HDMI Equalization Settings
  • 4 Stereo Analog Audio Inputs
  • 6 Digital Audio Coaxial Inputs
  • 2 TOS-Link Optical Digital Audio Inputs
  • 7.1 Channel Audio Output
  • Parametric Multi-Band Equalizer
  • Rear Panel Ethernet Connection
  • 1 Low Voltage Output Trigger (Power Amplifier)
  • 90-260 Volts AC 50/60 Hz 30 Watts
  • 13 lbs 1.75"H x 19"W x 16.5"D
TEQ-8
  • Balanced & Unbalanced Inputs (selectable)
  • Balanced & Unbalanced Outputs (selectable)
  • Features Trinnov's Setup Software
  • Front Panel Controls - Optimizer On/Off, Acoustic Correction On/Off, Level Adjustment On/Off, Delay Alignment On/Off, Bypass and Volume Control
  • Volume Control Integrates with ADA's Suite 7.1 HD
  • Front panel connection for Microphone
  • Low-Voltage DC Triggers (Power Amplifiers)
  • Ethernet Control Port (PC Setup & Control)
  • ADA Bus® Data Port (ADA Preamplifiers)
  • VGA Display Jack and USB Port (mouse)
  • 90-260Volts AC 50/60Hz 40 Watts
  • 23 lbs 3.5"H x 19"W x 17.5"D
PTM-8100BAB
  • 8 Channel 4 Zone Power Amplifier
  • 75 Watts Per Channel @ 8 Ohms
  • 140 Watts Per Channel @ 4 Ohms
  • 2 Ohm Minimum Safe Impedance
  • 0.01% Total Harmonic Distortion @ 8 Ohms
  • Low Voltage Triggers
  • PAC Programmable Amp Controller
  • 2U Fan Cooled Chassis
  • Torroidal Power Transformer
  • 600 Watts Maximum Power Consumption
  • 1024 BTU's/Hr Thermal Dissipation
  • 115 VAC Fuse Value 5A Slow Blow
  • 230 VAC Fuse Value 2.5A Slow Blow
  • 33 lbs. 3.5"H x 19"W x 16.5"D
1 - 1 of 1 Posts
