1 - 2 of 2 Posts
Discussion Starter #1
Up for sale is an excellent subwoofer that will, if you want, rattle the house! I have the original packaging and instructions. Very good condition. Normal signs of use on top, including a 1/4" nick in the top corner. 100% perfect in operation.
Price: $165 + shipping (or local pickup in Rochester, NY)
Description:
Listeners who want to treat themselves to the best in home theater sound need look no further than the BIC Acoustech H-100 front-firing subwoofer, which reproduces powerful, room-filling bass. Featuring 150 watts of continuous power output (500 watts peak) and a 12-inch, front-firing, long-throw woofer, the H-100 makes movies sound explosive and gives music a deep, full-bodied appeal--all without causing unwanted boominess or distortion. The subwoofer delivers a wide frequency response of 24 to 200 Hz, along with a max acoustic output of 115 dB SPL (sound pressure level). It performs particularly well when teamed with Acoustech's other home theater speakers, which are customized to match the subwoofer's output.
A further bonus stems from the sub's striking rear-vented cabinet, which is outfitted with a high-gloss black finish (think piano surface) on the top and bottom. The finish adds extra flair to the sub's design, as does the copper color of the woofer (revealed when you remove the grille).
Specifications:
Woofer - Long-throw 12"
Power - 500 watts dynamic peak output (150 watts RMS continuous)
Max Acoustic Output - 115 dB SPL
Frequency Response - 24 Hz -200 Hz (+/- 3 dB)
Enclosure - vented
Dimensions - 17" H x 15 W x 18 1/4" D
Weight - 42 pounds
1 - 2 of 2 Posts
