1 - 7 of 7 Posts
I am the original owner of a Emotiva UPA-200 2-channel amplifier. It's been patiently waiting (still in the original box - never opened) in my office while I planned one day to put it to use in my home for 2-channel listening. Alas, the time has come for me to face the facts - I'm never going to use this fine piece of equipment and rather than let it sit unused any longer, I'd like to find it a new home.
Asking $280.00
If you live in the Dallas/Ft. Worth, Texas area, I'm happy to arrange a pickup location. Outside this area, shipping costs to your destination apply. Please PM me for any additional information.
From the owners manual:
Specifications
Topology: Fully discrete, dual differential, high current, short signal path Class A/B.
Number of Channels: 2
Power Output (rated power; THD < 0.05%):
  • 125 watts / channel (8 ohms; all channels driven).
  • 200 watts / channel (4 ohms; all channels driven).
Rated Power Bandwidth (at rated power; 8 Ohm load): 10 Hz to 20 kHz + / - 0.1 dB.
Minimum Recommended Load Impedance: 4 ohms (which equals one 4 ohm load or two paralleled 8 ohm loads per channel).
Frequency Response: 5 Hz to 80 kHz + 0 / - 2 dB.
THD + N: < 0.03%
Signal to Noise Ratio (8 Ohm load):
  • > 92 dB at 1 watt (A-weighted).
  • > 106 dB at rated power (A-weighted).
Damping Factor (8 Ohm load): > 500
Speaker Output Connections: Full-sized 5-way binding posts; one pair per channel x 2.
Power Supply:
  • 350 VA high current ultra-low noise toroidal power transformer.
  • 40,000 uF of storage capacitance.
Input Sensitivity (for rated power; 8 Ohm load): 1.1 V (for full output; 8 ohms).
Gain: 29 dB.
Input Connections: Unbalanced (RCA); one per channel.
Input Impedance: 47 kOhms.
Trigger:
  • Trigger Input: 5 - 20 V (AC or DC); < 10 mA input current required.
  • Trigger Output: 12 VDC; can drive any load up to 50 mA.
Power Requirements: 115 VAC or 230 VAC +/- 10% @ 50 / 60 Hz (automatically detected and switched).
Front Panel Controls and Indicators:
  • Standby; push button (changes color to indicate Standby or On).
  • Status LEDs (one per channel); illuminate blue for normal operation or red to indicate a fault (may be disabled by rear panel Status LED switch).
Rear Panel Controls:
  • AC Power switch; rocker switch (switches AC mains power).
  • Status LEDs switch; small slide switch on left rear (disables front panel Status LEDs).
Protection:
The UPA-200 is protected against excessive operating temperature, shorted speaker connections, ground faults, and other common fault conditions. If a fault occurs, the UPA-200 will return to Standby mode, the Standby push button will light amber, and the Status LEDs will flash red.
Dimensions: 17” wide x 3.375” high x 16.5” deep (includes feet and binding posts).
Weight: 24 lbs (net); 32 lbs (packaged).
Emotiva UPA-200
Is it still available? Payment by PayPal OK? Cost for shipment via Fedex Ground to Scottsdale, AZ 85250?
Jack
Discussion Starter · #5 ·
Jack
Hey Jack -
PayPal is fine and FedEx Ground will cost $40.72 (32 lbs. 21x21x8 from 75022 to 85250)
If you would like to purchase, send me a private message and we'll exchange details.
-Stephen
1 - 7 of 7 Posts
