  • You have not yet participated enough to use the Marketplace
FS:Screen Innovations Zero Edge Pro 150" 16:9 screen with LED backlighting-Denver, Co
899 Views 0 Replies 1 Participant Last post by  crayneogeo
5
I acquired this screen as a part of a partial home theater removal. It is 150" diagonal total size and includes the LED backlights. The frame is removable if you want the zero edge look, or replaceable with many other color options evidently. I am guessing the screen material is the pure grey, but I do not know for sure. With the frame on it is around 145" screen size.
The screen was folded by whoever pulled the theater and after install it still needs to be placed out in the sun or warmed to remove some creases. I tried to capture the lines in one of the pictures, also the LED controller needs a new IR eye and remote, or if I was using the screen I would replace it with an IP controller and connect to a Hue or equivalent hub. Right now it only lights up to the default white.
This is available for local pickup only in the Denver area zipcode 80134.
The reason I am selling is my current theater screen is exactly the same size and AT. I do not have the room in my theater to have this size screen without it being AT.
$1000 or best offer. I am available this weekend to show the screen. Please text me at 847-274-4446 with any questions.
See less See more
  • Like
Reactions: 1
1 - 1 of 1 Posts
1 - 1 of 1 Posts
