Hello all,
Room info:
Basement HT, 18' x 16' with 8' 9" from slab to I-beam joists. The above family room is all hardwood floors.
I'm having a hard time finding RC2 resilient channel locally. Would hanging drywall from 2x2 furring perpendicular to the joists give me about the same result as RC2?
Or,
Since I have 8' 9" to play with, would you recommend a drop ceiling instead? I do need to build a soffet outta MDF to hide an HVAC duct. I may run the soffet all the way around the ceiling for aesthetics.
Also, two walls are poured concrete. I plan on 2x4 framing an inch or so away from the wall with R11 batt insulation. Should I also put up 4 mill poly between the batt and drywall for vapor barrier or is the batt enough? I'm in NE Atlanta.
Scott
Room info:
Or,
Scott
