The kit cost less than the parts would cost. So if that's over the budget, and you wanted to switch out a woofer to something cheaper, it would completely change the speaker and crossover network. If you change parts of the speaker or change the front baffle (like spacing or recesses), it will also change the end result. You would likely be better off going with a cheaper kit versus changing one of the mid priced ones.
