Status
Not open for further replies.
1 - 4 of 4 Posts
Has anyone else seen the following problem with FusionHDTV? I would like to send this problem to Dvico, but don't have an email address for them.
The "TV Audio Input" selection isn't retained. The application always defaults to CD Audio In. This is quite an inconvenience since I must change the configuration every time I start the application.
This problem only effects the analog tuner function of the card.
System Configuration
Win XP
P4 2.26GHz/.533GHz
512MB RDRAM
GeForce2 Pro
Asus P4T533-C Mainboard
To be honest, I don't know. Mine stays put to whatever input I tell it, when I tested it.
But...I only use the CD input for that card's analog output.
Is there a reason why you can't use your soundcard's CD input specifically? You generally don't want to use it for the CD-ROM drive's analog output, as the ADAC in the CD-ROM is going to be very inferior to pulling the sound digitally over the IDE bus... as most modern day CDplayers will allow.
Discussion Starter · #4 ·
In order to reproduce this you must:
1) open the application
2) change the channel via keyboard
3) close the application
4) open the application
I haven't seen the failure occur without this procedure.
1 - 4 of 4 Posts
Status
