Hi,
I'm EXTREMELY new to the HTPC world but am trying to get setup to receive OTA HDTV in time for the Superbowl next weekend. If it helps I live in the SF bay area, 94041.
I got my hands on a Fusion HDTVII tuner card and installed it in an older PC that just meets the minimum system requirements (P3 800, ATI Radeon card) I installed the software that came in the box, which I think was 2.1. Should I locate a faster PC, or has anyone had luck with their minimum requirements?
I'm using a cheap Rado Shack indoor antena for the signal, and feeding the video output to a SE1HD (Sanyo PLV-Z1) front projector.
I used the "auto scan" feature to have the card scan all the OTA channels and determine which ones it receives a signal on. I managed to tune in several analog channels and a two digital channels.
All I care about right now is tuning in CBS for Sunday's superbowl. I looked on titantv.com and found that this is on channel 29 for me. Here's my question:
What I would like to do is set the tuner for channel 29 and adjust the rabbit ears until I can get decent reception. It would be REALLY useful if there is a function where I can get the display to show me signal strength. Can that be done? If so, how?
Any other tips for me from people in my area who are able to receive CBS over the air?
Thanks in advance,
Thanks in advance,
