1 - 1 of 1 Posts
· Registered
Hello,
here is my setup:
HTPC =
Antec NSK2480 Desktop case
GigaByte GA-E7AUM-DS2H
Intel Dual Core E5200
Hitachi Deskstar 7K1000 1TB
Corsair XMS2 TWIN2X4096-6400C5/G 4GB Kit 800Mhz
my TV = sony 40W4000
htpc is running kubuntu 64bit.
i'm connecting via HDMI, got an image but resolution is wrong, it is off in the edges, fonts are tiny.
quantumstate is kindly helping me to troubleshoot and it seems to be a problem with the EDID of the TV. here is extract of the Xorg logfile:
Code:
Code:
II) Loading /usr/lib/xorg/modules//libwfb.so
(II) Module wfb: vendor="X.Org Foundation"
        compiled for 1.5.2, module version = 1.0.0
        ABI class: X.Org ANSI C Emulation, version 0.4
(II) Loading sub module "ramdac"
(II) LoadModule: "ramdac"
(II) Module "ramdac" already built-in
(II) resource ranges after probing:
        [0] -1  0       0xffffffff - 0xffffffff (0x1) MX[b]
        [1] -1  0       0x000f0000 - 0x000fffff (0x10000) MX[b]
        [2] -1  0       0x000c0000 - 0x000effff (0x30000) MX[b]
        [3] -1  0       0x00000000 - 0x0009ffff (0xa0000) MX[b]
        [4] -1  0       0x0000ffff - 0x0000ffff (0x1) IX[b]
        [5] -1  0       0x00000000 - 0x00000000 (0x1) IX[b]
(**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
(==) NVIDIA(0): RGB weight 888
(==) NVIDIA(0): Default visual is TrueColor
(==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
(**) NVIDIA(0): Enabling RENDER acceleration
(II) NVIDIA(0): Support for GLX with the Damage and Composite X extensions is
(II) NVIDIA(0):     enabled.
(II) NVIDIA(0): NVIDIA GPU GeForce 9400 (C79) at PCI:2:0:0 (GPU-0)
(--) NVIDIA(0): Memory: 524288 kBytes
(--) NVIDIA(0): VideoBIOS: 62.79.3c.00.09
(--) NVIDIA(0): Interlaced video modes are supported on this GPU
(--) NVIDIA(0): Connected display device(s) on GeForce 9400 at PCI:2:0:0:
(--) NVIDIA(0):     SONY TV XV (DFP-0)
(--) NVIDIA(0): SONY TV XV (DFP-0): 165.0 MHz maximum pixel clock
(--) NVIDIA(0): SONY TV XV (DFP-0): Internal Single Link TMDS
(WW) NVIDIA(0): The EDID for SONY TV XV (DFP-0) contradicts itself: mode
(WW) NVIDIA(0):     "1920x1080" is specified in the EDID; however, the EDID's
(WW) NVIDIA(0):     valid VertRefresh range (48.000-62.000 Hz) would exclude
(WW) NVIDIA(0):     this mode's VertRefresh (24.0 Hz); ignoring VertRefresh
(WW) NVIDIA(0):     check for mode "1920x1080".
(II) NVIDIA(0): Assigned Display Device: DFP-0
(==) NVIDIA(0):
(==) NVIDIA(0): No modes were requested; the default mode "nvidia-auto-select"
(==) NVIDIA(0):     will be used as the requested mode.
(==) NVIDIA(0):
(II) NVIDIA(0): Validated modes:
(II) NVIDIA(0):     "nvidia-auto-select"
(II) NVIDIA(0): Virtual screen size determined to be 1920 x 1080
(--) NVIDIA(0): DPI set to (30, 30); computed from "UseEdidDpi" X config
(--) NVIDIA(0):     option
(==) NVIDIA(0): Enabling 32-bit ARGB GLX visuals.
(--) Depth 24 pixmap format is 32 bpp
has anyone similar problem? someone could advise me on how to solve that pb?
many thanks
1 - 1 of 1 Posts
