1 - 5 of 5 Posts
I have had a Da-Lite Video Spectra (1.5 gain) 106" diag, 92 in wide for over 10 years. I have been thinking of upgrading to a bigger screen, 119" diag, 104 inches wide.
After reading several posts here (thank you Tryg!), I decided to consider the Da-Lite High Power screen. Tryg also suggested that I check the gain calculator that flboy put together (thank you flboy!) to help me make a decision.
After running the calculations based on my seating arrangements (which cannot be changed) I got the following results:
L= left C= Right R=Right
High Power (106" Diag) 1.11 L, 1.10 C, 1.11 R
High Power (119" Diag) 1.11 L, 1.10 C, 1.11 R
Video Spectra (106" Diag) 0.85 L , 1.46 C, 0.85 R (my current set-up)
Video Spectra (119" Diag) 0.82 L, 1.46 C, 0.82 R
It looks to me as if the Video Spectra (VS) gives me a brighter sweet spot in the center than the High Power (HP) but a degrading image toward each side.
Does it make any sense to consider switching from a VS to a HP? I am trying to go to a bigger screen without degrading what I already have.
Any other options I should consider?
BTW, I have a JVC RS1 projector projecting from the ceiling onto a screen that is about 15 feet away. I sit about 15 feet away (under the projector basically). The projector is several feet over my head; the screen is a Da-Lite Cosmo electrical ceiling mounted.
Originally Posted by FLBoy /forum/post/19608090
Sure he can, Doug. All it takes is an extension pole.
Nicoff, try a few lower PJ positions in the gain calculator, and watch the magic begin!
Ah, shoot. A pole. That's what I should have done.
I just built my pj into the bar to get it low.
After 1000 hours on the bulb my 52 square foot screen is still bright as can be - and on middle iris setting too. That is why you do the high power.
1 - 5 of 5 Posts
