Greetings AVS Forum. I have a RP Samsung DLP (HLP5674WX) with ~4000 hours and have been very pleased with its performance up to this point. Unfortunately it has developed an issue with a bad DMD board. With the bad board, a new bulb in my future and a little money to spend, I am opting to replace the TV rather than having it fixed. I have the following criteria:
>55 inches
Budget of $1500 but could go up to $2000 for a big jump in picture quality or less quality issues down the line
TV will be used for sports, blu-ray movies, HDTV, and videogames (360 and PS3)
Seating distance is 14 feet on a stand
No issues with viewing angles with the DLP
RBE not an issue as I have a DLP RP in the living room and a DLP projector in the den
I have considered the following TVs:
Panasonic TCP58S1
Samsung PN58B550
LG 55LH40
Mits WD60C9
LED is out of my price range for the size
I went to four different stores and checked out TVs for a number of hours. I was the least impressed with the RP DLP (still pretty good) compared to the plasma and LCD pictures, and in most cases, the LCD was brighter than the plasma; however, I am aware the TV will look differently in my home.
I have looked at the pros and cons of the technologies, but still can't make up my mind. I started with DLP but the LCD and plasmas looked better. Then plasma, but the increasing blacks scarred me off. Then LCD but the motion/video game delay of LCD has me worried. All in all a bit confused. Any suggestions? Thanks.
>55 inches
Panasonic TCP58S1
Samsung PN58B550
LG 55LH40
Mits WD60C9
