1 - 8 of 8 Posts
Premium Member
I appologize if this has been answered before, but I am new to the anamorphic scene and I had a simple question. I have a 138" 2:35 screen and a throw of about 14 ft. I have a JVC RS1 and can easily throw a 16:9 image (110") on the screen from that distance, but am unable to zoom it out enough to fill the entire 138" anamorphic picture from that distance. My question is: If I use an anamorphic lens, would it stretch my 110" 16:9 image out to fill the entire 138" 2:35 screen? This would be the only way I could fill my entire screen since I am limited to a 14' throw distance. Thanks for the help
With a lens you would expand the 110" wide image by 33% which would give you 146" width, so you could actually zoom the RS1 back a little to fit the image on the screen, which would also increase your throw figure (this is good
Put another way, you'd have a 16:9 image of approx 104" wide if you were setup with the lens to fill your 138" wide 2.35:1 screen (104=138/1.33). The 104" 16:9 figure combined with the 14' distance would give you a throw of 1.6 (14' = 168", 168/104=1.6) which isn't ideal but still workable (depending on which lens you use). You may get a little more pincushion with this short throw, but this could be lost by slightly overzooming and it would be hidden by the screen border.
I hope this helps.
The answer is yes, it would as long as the anamorphic lens is a horizontal expansion lens (not verticle compression lens) AND the lens can handle that small of a throw ratio. The dimensions you provided results in a throw ratio of about 1.62, and is typically too small for many commercial anamorphic lensesthe overall result could introduce vignetting.
Premium Member
Discussion Starter · #4 ·
Thanks for the quick replies. I would probably use a Home Theater Brothers or something comparable in price. I wanted to keep it under $500 and this seems to be my only option to filling out the entire width. I would be happy to take any other suggestions on lenses. Thanks
Look out for a used Isco II lens. This is what I use and it's quite a bit sharper than prism lenses and it has astigmatism (focus) adjustment for the sharpest image. I don't know what they go for over there though. I have a HD350 at a longer throw, which means I hardly get any pincushion, though my screen is only 112" wide, so smaller than yours.
Not to mention, it is also corrected for CA as well
Does the ISCO II handle a 1.6 throw ratio?
1 - 8 of 8 Posts
