1 - 2 of 2 Posts
What is the difference between turning up the volume control on the subwoofer OR increasing the channel level volume in the receiver settings? I have a Denon 2807 and Polk PSW505
"Daddy sang bass, momma sang tenor"
No difference, really. It's nice to have some room to work on the receiver side for ease of adjusting the sub level. So if the receiver level is at max, you would not be able to bump up the level if desired. So I would set the sub level so that you have some adjustment room.
1 - 2 of 2 Posts
