Status
Not open for further replies.
1 - 4 of 4 Posts
Welp im getting a 9200 sometime this week. I was wondering if there is any general repairs i should do to it before i bring it home from my tv shop. I know there is some preventive maintenance stuff that i can only do at the shop, so id like to get it over with all at once. So any cap changes or other mods i could use would be helpful. Also any fan replacements i could use to replace any loud ones ( they are 10 years old) with panaflos or something would be apericated(sp).
 http://www.avsforum.com/avs-vb/showthread.php?t=556607
http://www.avsforum.com/avs-vb/showthread.php?t=550435
http://www.avsforum.com/avs-vb/showthread.php?t=360250
Change Cap on Def board (get the tv guy to do this one)
Add fan to Def board heatsink over big Toshiba transistor - just power it with a 6 volt plugpack is easiest - although it can be wired in with a 100 ohm 1+ watt resistor in series.
Add a heatsink to the bottom plate, under the C and F drive STK chips. I just put in longer M3 screws to hold the C and F drives - then put the heatsink over the sticking out threads on the underside, and added M3 nuts. A fan on this heatsink wouldn't hurt either.
If it drifts change caps on Waveboard.
Mark
It
1 - 4 of 4 Posts
Status
