I just tried to clean the air filter on my Proxima DP-6850 with a vaccum cleaner and it tore so I need a replacement.
From this thread http://www.avsforum.com/avs-vb/showt...9#post13769699 Sheridan1952 suggested a "very thin open cell foam sheet".
I'm thinking something like this would work since it seems like all I'd need to do is cut the sheet to size. Would this be my best bet and if so where can I find this cheap? Ordering a replacement from Projector Doctor is $19 and that seems like a ridiculous price for something like this. Thanks.
