Yes, no, sorta.
If you only care about channels that your cable provider leaves in the clear, either as analog NTSC or unencrypted QAM (ClearQAM), then any old HTPC with a tuner card will do.
If you want channels that are encrypted, you will need to buy a whole PC with a CableCARD tuner from one of the PC manufacturers such as HP, and get a CableCARD from your cable provider. Currently this is the only way you can get CableCARD capability on your PC.
