1 - 3 of 3 Posts
· Registered
I am building my first htpc and have done a pretty good job so far. I have everything in the chassis, just finishing up the chassis connectors then the power for each item.
I have 3 connectors I am not sure where they go on the motherboard.
1. Power SW
2. HDD LED
3. Motherboard USB - This is a 4 pin connector which I did connect to the 2nd usb connector on the MB. Not sure if this is correct.
I connected the blue and white connector, power led in slot 11.
Thanks for your help.
Jim
· Registered
Discussion Starter · #3 ·
1. Power SW
2. HDD LED
Jim
Looks like I have everything connected, so I booted up and nothing on the screen. I have a feeling it is because I am connecting the monitor via hdmi to the hd4890 card. Do i need to connect via dvi or vga to get this going?
Jim
1 - 3 of 3 Posts
