Status
Not open for further replies.
1 - 1 of 1 Posts
Hello,
Due to the room shape, I would want to place my gigaworks subwoofer/amplifier rather far away from my computer. Thus, the included wire is not long enough.
The wire in question has one end that branches out in three connectors (for plugging into the soundcard), out of which one is a 3-pole connector and two are 4-pole connectors.
The other end branches out in four connectors (for plugging into the subwoofer), all of which are 3-pole.
As 4-pole connectors seem very difficult to find, I assume the best way to extend this cable is to simply add four extensions to the subwoofer side of the cable, as these are all 3-pole? But will this actually be possible? Are they "real" 3-pole connectors on that side, or is there some other problem that will affect quality etc? Thanks.
1 - 1 of 1 Posts
Status
