141 - 160 of 261 Posts
Banned
Discussion Starter #141
Banned
Discussion Starter #143
So does one of these equal 2 Johnny subs?
I think it's closer to 3 "Johnny's"
Ltd posted graphs earlier on in the thread, subjectivly it stomps all over my 4 sealed uxl's.
"Why would anybody need one, let alone two of these. "
It's complicated:
https://images.search.yahoo.com/search/images;_ylt=AwrSbgJZ6EZYfTYAYjtXNyoA;_ylu=X3oDMTEycTZscGd2BGNvbG8DZ3ExBHBvcwMxBHZ0aWQDQjI5MjZfMQRzZWMDc2M-?p=It's+Complicated&fr=mcafee
FTR after helping @kevings off the launch pad and even deeper into the rabbit hole and as of last spring seeing the 3 full sized Marty's we built in action (before he added the sealed NF 21"), I can't think of any good reason to not build it.
As I told @LTD02, for a mere $300 or so, why not help the cause, enable my OCD, and see how the advancing theory of design works out.
http://southpark.cc.com/clips/154238/totally-worth-juvenile-hall
also, not having anyone to tell you NO!
Banned
Discussion Starter #146
What a crazy hobby this is. It really is bordering on insanity. :eek: Why would anybody need one, let alone two of these. I wish I had the space for a couple of these.
For me it was curiosity, I couldn't find anyone local with a horn loaded sub.... So I figured, why not build one..or two.:D
So glad I did.
Banned
Discussion Starter #148
Fattykid, when you have to schedule your listening tests around your neighbour's schedule... you really might have a problem. :)
I pity your drop ceiling. Are the tiles literally jumping in the T-bar?
I try to be cool with the neighbors when I'm planning on running sweeps and sine waves.. Movies, they seem to be cooler about.
I have the ceiling weighted down. It helps.
.02 wrt FLH
after enjoying immensely the many impressive/superior design/response qualities of 3 BFM THTLP's, a 24" and 2 30"'s and drinking/drowning in the Kool-Ade ,
(working with 1/2" ply serious challenge but the answer is:IITP)
the 1 thing that raised an eyebrow was a comment by Bill that 15's were good enough for a well designed FLH,
he should know, Right?
he's got a picture of a destroyed 18 that indicated, 18's can't cut it . .
but meanwhile, I was still thinking . . what if there was 1 that could?
and LTD02 had his original thread that had died wrt V2, nobody wanted to take that on . . .. 38 ft^3
lazy guy that I am, the thought of using 3/4" ply, multiple tubes of PL3X and a ton of kreg screws . . .
easy -peasy
and going to an inuke amp and having a few more options over a BASH 300 wrt EQ, etc.
Not knowing what i was doing? no problem!
just build it the right way . . .
and the rest, as they say, is just totally F'n awesome woofage.
That's why . .
  • Like
Reactions: LTD02
Beautiful looking mouth bracing! If you got the room, post a pic of both subs lying down with the mouths side by side. I bet that's gonna look awesome!
yeah, that let's stand them up, now, lay them down, then stand it up again thing
these things don't' do burpees ,
the idea of a lower knee, indeed some magnificent engineering, but . . . . .
at about 300+#'s if you can get it on a dolly , either vertical or horizontal, you have a tendency to leave it there,
building this thing, piece of cake
playing waltzing matilda with it, a considerable serious effort.
if you want to destroy yourself, let the sub do it while you sit there grinning your butt off . .
short hop up a few steps?
I got lucky - big A$$ refrigerator dolly and built in tightening strap and 2 extra bodies
if you really want to see 2 well performing mouths in action -
well, many of us have seen that movie,
otherwise, i recommend photoshop
V2 meets V3
sorry, best I could do . . .
  • Like
Reactions: Fattykidd and LTD02
V2 meets V3
when you click on the paperclip to attach a file, can't you import a full resolution version of your picture?
if you are having difficulty linking it up, shoot me a pm and we can sort it out. didn't seem like you were having any issues before.
Banned
Discussion Starter #155
LMFAO !!!!! I want to unlike this so I can like it again.
that's AWESOME!
Thanks John. I hope it's something you're proud to have your name on.
It's easily the most incredible sub I've ever heard, thank you sir.
  • Like
Reactions: LTD02
LMAO..... @Fattykidd we are not moving these around for a photo ..... my shoulder is only just now feeling better
Back on the second one tonight!!!!
that's AWESOME!
Yes I really hope we have done you proud John
Great design and the cut sheets and drawings helped immensely for the build
Kudos to you!!!!
time for some coffee and remedial posting lessons
maybe
  • Like
Banned
Discussion Starter #160
A little progress on #2
