I rent my apartment so theres not much I can do with the walls. Because of this I was wondering what you guys thought about using Foam Board. These are the ones that are available in my local HD: http://www.homedepot.com/b/Building...Z12kxZ12kyZ1z11605?NCNI-5&Ns=P_REP_PRC_MODE|0 (except for the pink one) Which one should I go with? I know Thrifty White is commonly recommended but since i'm renting I don't want to mess too much with the plaster wall.
I want to keep it simple so I would like to go with a neutral gray paint: http://www.homedepot.com/p/Glidden-Premium-1-qt-Flat-Interior-Paint-GLN9013-04/202241866
This will be used in my bedroom where I have some really shiny white walls. So i'm wondering what gray I should go with? How do I ask for it? And how much paint do I need for an 82" screen?
Also will I have to prime the surface? If so what primer would work best with this material?
My PJ is a Benq w1070 which i'll be using mostly at night.
