Status
Not open for further replies.
1 - 2 of 2 Posts
Hello. I am looking for a 30in widescreen directview set to use with my htpc through rgb, or dvi. Preferably, I dont want to have to use a transcoder to input the signal over component.
Can anyone reccomend a good unit? I have tried to do some research on this, but the information seems to be hard to find. Many thanks.
Search for the words "Monivision" and "Princeton Graphics" across all forums. You will get a wealth of information on the 30" widescreen monitors with VGA/RGB inputs that supports 1280x720 natively.
I would recommend the 30" widescreen Monivision monitors or the CTX and Princeton Graphics 30" monitors.
1 - 2 of 2 Posts
Status
