1 - 3 of 3 Posts
In need of a good universal remote to work the panasonic DMR-EZ48 dvd recorder with a sony trinitron tv and a panasonic DMR-EZ48 dvd with a sharp lcd lc19dv12u tv. As you can see I'm not too high tech. the DMR-EZ48 has some features missing that I would like to have covered and the sharp remote is terrible to try to operate. thanks for your help
If you get a cheap UEI remote (One-For-All, several cable remotes, radio shack 15-100, 133, 134, 135, etc.), THIS post has the setup code and all the commands for the EZ485. The radio shack 15-133 is $20 and often goes on sale for $10. If you go that route, post back, and someone can give you the sharp codes. The How To link in my sig tells you how to program all those codes.
1 - 3 of 3 Posts
