Status
Not open for further replies.
1 - 3 of 3 Posts
Any good Ideas for a center channel to match my monitors. The monitor audio centers are way too big to fit in my setup. Any center that is relatively compact that would work (in a timbre matching sense). My rears are the Axion QS8's which are working out quite well. I was thinking about the Axiom center, but I wasn't sure. Any comments or ideas?
I think you will find that the Axiom centers are the same size (or close to the Monitor Audio ones). I would go with the smaller of the two monitor audio center channels. Look at this link http://cgi.ebay.com/ws/eBayISAPI.dll...category=14992 . It may be useful to you. Your best bet for timbre match is to go with the same speaker manufacturer.
Good Luck
Dave
1 - 3 of 3 Posts
Status
