I built an HTPC not to long ago using a Haupauge 1800 card. The HD capture is fine, but the SD leaves alot to be desired. I was hoping to replace my Series 1 Tivo but the PQ is so bad in SD that I have kept the Tivo and use it for all SD recording still.
Does anyone have a recommendation for a quality SD tuner card? I have a 2.5ghz quad core with 4gb ram so computer speed should not be an issue.
