I will post my settings for each input I'm using on my Sony 42A10 as I've gotten several PMs asking for it. We should probably keep bumping this thread to keep it active for a awhile.
These settings are for low/mid-level lighting for day and night viewing. These settings give a more "flat" look since my lighting conditions do not change very much. I don't like overly contrasted/saturated whites or colors. Fine detail is lost and it causes eye strain which makes viewing the TV less enjoyable.
Viewing distance from my 42A10 is around 7 to 8 feet.
Update settings for red push fix - 9/6/06
Some confusion has arose out of which settings look best. IMO you should be using these two settings for every input to get the best color rendering from the A10's color decoder:
CH_ITU_MODE1 - 0000
CH_AXIS1 - 0017
*Both settings need to be be changed to the values listed. Read the first post in this thread for instructions on how to fix the red push. Be sure to write down the default values BEFORE making ANY changes in the service menu.
***Grayscale Tweak***
Update 9/7/06
I'm back to using this tweak.
***BE SURE TO WRITE DOWN YOUR DEFAULT SETTINGS BEFORE MAKING ANY CHANGES IN THE SERVICE MENU***
The first step is getting into the SM. Follow the same steps that you do for the red push fix:
(step -1) Start with a TV where all needed inputs have already been configured to best custom mode settings
(step 0) If necessary turn off TV and wait for bulb to turn off
(step 1) Press the following 4 key sequence without a pause:
(display) (5) (Volume +) (Power)
(step 2) Wait the normal turn on time for the debug screen to appear
(step 3) Press (jump) twice to get to service data screen
***Grayscale fix starts here***
(step 4) Press (5) four times to get to the D9809PIC item.
(step 5) Press (1) four times to get to the RGAIN setting.
(step 6) Press (6) three times. This will be your new RGAIN value.
***Note that the above setting is for an Iris setting of 1. I've changed my Iris setting to 2 for all inputs and the value above will be different. My RGAIN setting is currently set to 007E.***
(step 7) Press (1) two times to get to the BGAIN setting.
(step 8) Press (6) sixteen times. This will be your new BGAIN value.
(step 9) To save the new values press (mute) (ent) and wait for write to complete.
(step 10) Press (jump) to return to the debug screen
(step 11) From debug screen press (power) to turn the TV off and wait for the bulb to go out
(step 12) Turn the TV back on and change the Color Temp to Warm 2 for every input you're using. You must be using a Custom picture mode to use Warm 2.
These settings are based on Bill's procedure to fix the grayscale. The above method is intended for those that use the Advanced Iris on LOW (Medium and High might need different values). What you're doing is getting the color temp very close to 6500k, which is the reference standard for the most natural color rendering on a display. If for some reason you don't like the look of 6500k, you can switch the color temp to Warm 1 or Neutral for a bluer look. You might find that Neutral looks a lot better now since it's tracking at about 9300k.
FOR YOUR REFERENCE
RGAIN - lower it by 3 clicks from your default setting
GGAIN - leave it at default
BGAIN - lower it by 16 clicks from your default setting
RBIAS - leave it at default
GBIAS - leave it at default
BBIAS - leave it at default
The settings above are based on Bill's (zmn668) settings. A big thanks go out to him for finding this tweak. The grayscale on your A10 may need slightly different settings to get it closer to 6500k. For better accuracy, it is recommended that you use a colorimeter or get your A10 ISF calibrated.
The settings listed below for my components should be used as a guide to help you get the most out of your A10. Obviously everyone has different tastes and different HT gear. So, simply use my settings as a primer and then adjust further if needed.
SD analog cable using the A10's RF coax input:
*Recommended for best PQ over the cable box analog tuner
*Calibrated by eye
Iris - 2
Picture - 80
Brightness - 48
Color - 31
Hue - G5 (*based on red push fix values above)
Color Temp - Warm 2
Sharpness - 20
Noise Reduction - Off
DRC Mode - High Density
DRC Palette -
Reality 40
Clarity 40
Black Corrector - Off
Advanced Iris - Low
Gamma - Max
Clear White - Off
Live Color - Off
HD and SD digital cable (Motorola 6412 HD DVR cable box w/component out):
*For 6412 Phase II or III units
*Calibrated with INHD tune up and by eye
Iris - 2
Picture - 80
Brightness - 48
Color - 31
Color Temp - Warm 2
Sharpness - 15
DRC Mode - High Density (*For viewing SD channels through the cable box)
DRC Palette -
Reality 40
Clarity 40
Advanced Iris - Low
Gamma - Max
Clear White - Off
Live Color - Off
DVD (Oppo OPDV971H w/DVI-HDMI out):
*Calibrated with Digital Video Essentials DVD
*DVD player set to upconvert to 720p
Iris - 2
Picture - 90
Brightness - 51
Color - 31
Color Temp - Warm 2
Sharpness - 23
Advanced Iris - Low
Gamma - Max
Clear White - Off
Live Color - Off
VCR (Hitachi HI-FI VHS 4 head player w/composite out):
*Calibrated by eye
Iris - 2
Picture - 80
Brightness - 48
Color - 31
Color Temp - Warm 2
Sharpness - 15
Noise Reduction - Low
DRC Palette -
Reality 30
Clarity 90
Advanced Iris - Low
Gamma - Max
Clear White - Off
Live Color - Off
