Status
Not open for further replies.
1 - 3 of 3 Posts
Need help.
I have a Sony XBR HI Def 40" and it is awesome
When I hook my PC via S video, the best readable I can get is 640 x 480 res, wiich is not acceptable.
I want to run my internet browser, but more importantly, good games on this TV
Is there a good PC graphces card I can buy that will produce nice 600 x 800 res or better?
I spend an hour in Comp USA with two idiot clerks, only to get P'd off and left.
Thanks in advance
Craig
I think a lot of people are not realising that the TV output is only standard def 640x480 interlaced video, no matter what resoultion they are trying to use.
To get a higher def signal, you must use the VGA ouput to the HD inputs of the TV and choose a resolution that your TV supports. Add appropriate software to scale and resize for exactly what you need and you have a great image.
Vegggas
1 - 3 of 3 Posts
Status
