1 - 20 of 138 Posts
Discussion Starter · #1 · (Edited)
Gravity 3D MKV... with ATMOS. How to do it? (Solved)
Here's a much more succinct approach for creating a 3D MKV file
So since they just released a new, allegedly very impressive (from Ralph's review) version of Gravity with an Atmos soundtrack yet failed to also make it a 3D version, I want to take the 7.1 True HD track with Atmos on it and mux it with the 3D MKV video file.
I'd like to figure out and detail the process here so that anyone who wants to do the same can do so with ease.
The first problem is finding something that will rip just the Atmos audio track (MakeMKV won't let you just rip audio) and then software that can merge the audio and video files AND that can handle not only Dolby True HD but one that knows how to handle ones that are encoded with Atmos. And, no, they're not one and the same. If they were then I'd be able to listen to Atmos on my Plex HT but I can't.
UPDATE:
So we've got one method from Manni01 that he tested with I, Frankenstein that he got to work (only on one of his players though):
Use tsmuxer to create an ISO from an MVC mkv of the 3D version, created with makemkv, and the Atmos soundtrack from the Japanese 2D version.
This worked fine, but was only playable with TMT, not PDVD. It might be playable on a 3D mediaplayer but my Dune Base 3.0 and my NeoTV 550 are 2D only, so I couldn't test.
Tsmuxer can rip the Atmos audio straight from the disc in the drive as long as ANYDVD is enabled. (Will DVDFAB also work?)
A more detailed step-by-step (again, from Manni01):
Here is a step-by-step that works for me (you need to have AnyDVDHD running in the background).
Important note/disclaimer: you need to own the original bluray of both the 3D and 2D version, otherwise what you are doing is illegal. It might still be illegal in your country even if you own both discs, so please check you local copyright laws, etc). The point here is to try to help legal owners of the two versions to watch a combined version of the movie until a proper 3D + Atmos version becomes available to purchase, not to encourage or condone piracy):
1) Use makemkv to make an MVC mkv rip of the 3D Bluray. The playlist to select is the one with the MVC video track. Select as many audio and subtitle tracks as you want.
2) Once you have an MVC mkv of the 3D Bluray, try it in your mediaplayer. If you have PDVD or TMT on a PC, none of them support MVC files properly, so don't waste your time. TMT doesn't play them at all, and PDVD will play them as a 2D movie converted to 3D, with black borders, so pointless. The only option on a PC able to play an MVC file properly AND bitstream the dolby Atmos track is stereoscopic player. It's unfortunately not an option with an AMD GPU due to the left eye delay bug I mentioned earlier, unless you have Windows 7 or earlier and can use Catalyst 12.3 or earlier. AFAIK it was the last version without the bug. With NVidia or Intel GPU, stereoscopic player should work, but you need to check, I only have an AMD 3D platform.
If your player supports MVC playback properly, you have now two options: keep the file as an MVC MKV and simply add the Atmos track with MKVToolnix, or do what you have to do if your player can't play MVC files properly, which is to convert the MVC back to a 3D BD ISO using tsmuxer.
3) In any case, use BD Info to identify the correct playlist on the 2D disc with Amos (from the original physical disc, no need to create an ISO first although it will work with an ISO or folder rip). If BD Info gives you too many options you can look at the disc.inf file created by anydvdhd in the structure of the bluray, the last line will tell you the valid file(s). You're obviously looking for the playlist with a dolby TrueHD track (there will be no mention of Atmos until tools are updated to identify the extra metadata, which is unlikely to happen any time soon).
4a) If your player is compatible and plays MVC files properly and if you want to keep the movie in mkv format, use mkvtoolnix to import the 3D MVC file and the 2D Atmos playlist from the physical BD reader, and create a 3D MVC file with both the 3D video and the Atmos (TrueHD) track. You'll have to deselect the 2D Video, and the non atmos tracks/subtitles that you don't want to keep. You might also move the Atmos track up so that it's selected by default in the new MVC file.
4b) If your player is unable to play MVC files properly or if you'd rather have an ISO version of the 3D Atmos movie, use tsmuxer to import the 3D MVC file and the 2D Atmos playlist from the physical BD reader, and create a BD ISO with both the 3D video and the Atmos (TrueHD) track. You'll have to deselect the 2D Video, and the non atmos tracks/subtitles that you don't want to keep. You might also move the Atmos track up so that it's selected by default in the new MVC file. The resulting ISO is only playable on my system by the standalone version of TMT (latest 6.5 in my case). It might be playable by other mediaplayers or software players, I haven't tested.
5) Cross your fingers that audio and video will be in sync, and enjoy a 3D version of your movie with a Dolby Atmos track
RESULTS:
Using mostly step 4b above, I was successfully able to make a 3D ATMOS ISO of Gravity using tsmuxer to mux the video files (MVC and H.264, from a 3D MKV file I had already ripped) with the True-HD Atmos track from an ISO of the disc I mounted on a clone drive using the (sheep) Virtual CloneDrive. To get the audio track, when you are adding files in the upper window of tsmuxer, you go to the clone drive, in my case K, and navigate to K:\BDMV\PLAYLIST\00098.mpls. From there you select the TRUE-HD audio codec in the lower window.
I've attached a picture of what my tsmuxer window looked like to make the ISO. It plays flawlessly. As you can see, the files from the two different discs are the exact same length. I am playing it on a KDLinks HD720 Media Player. Can't guarantee that it'll work on everything.
I went with the ISO approach because installing all the necessary components for mkvtoolnix to run seemed a bit daunting. On the other hand, tsmuxer was an all-in-one solution with a GUI.
Good luck everyone!
Update:
Here is some info from Batiatus Rules on making it into an MKV:
For now, and for my purposes, I simply used MakeMKV to rip both the 3D Blu-ray and the 2D Atmos Blu-ray into MKVs. Then opened MKVToolNix and muxed the 3D MVC video, chapters and subtitles from the first MKV with only the TrueHD7.1/Atmos audio track of the second MKV. Took about 25 minutes to compile and I have 1 perfect 3D MVC MKV Atmos file. No sync issues, no playback issues in Kodi 14/15 and just in fact finished watching it and it looked fantastic and sounded amazing!
RIPPING THE AUDIO:
It appears that DVD AUDIO EXTRACTOR can handle blu-ray audio. I'm going to give this one a shot first.
MERGING AUDIO AND VIDEO:
Not sure... can mkvtoolnix do this?
AnyDVDHD, tsMuxeR,BDinfo are all you need.
Rip both movies to hard drive using AnyDVD HD.
Mount both movies using Virtual Drive
Demux the Atmos out of the movie using tsMuxeR.
Load the 3D version into tsMuxeR with correct playlist found from BDinfo.
Add the Atmos track
Uncheck the DTS HD Track
Check the Atmos track
Create new ISO with tsMuxeR.
My only concern is will the Audio and Video be in Sync.
Discussion Starter · #5 ·
ISO is the way to go here. Not MKV. 3D Dunes, KD LInks Media players and PCs will all be able to play 3D MVC ISOs
Is there a reason to avoid 3D MKVs? I make all my 3D movies MKVs. The KDLinks plays 3D MKV files as well.
Most PCs, the Dunes, KDlinks 720, HTPCs and stand alone players without cinavia seem to handle ISOs the best. It is easy to create an actual disc from ISO using BD re builder. It is a more elegant solution.
Thanks very much for this!
Add the Atmos track
Premium Member
Add the Atmos track
Have you actually tried this yourself?
There are a few things that I don't understand in your suggestion.
1) If you rip to hard disk, AnyDVD creates bd folders and doubles the size of the movie, not an ISO. Do you mean copy to image?
2) If you copy to ISO, why do both version? If it's just because you don't have two physical drives, then only one is needed. Tsmuxer can read from the physical disc directly as long as anydvdhd is enabled, it makes no difference vs mounting an ISO.
3) can tsmuxer handle the 3d structure with the ssif folder when you create the new ISO? I assume it's going to be huge otherwise.
If you have tried and if it works, I'll try this. I managed to create an MVC mkv file using makemkv and mkvtoolnix but the resulting mkv mvc file isn't playable on my AMD HTPC due to the left eye AMD bug.
Premium Member
@blackssr:
I own a 3D UK version and a Japanese 2D version of I, Frankenstein and I tried your method of using tsmuxer to combine the 3D video and the 2D Atmos directly.
It didn't work. It generated an apparently correct ISO, which could be loaded, and which had the SSIF folder, but it wasn't playable by either PDVD or TMT.
So I tried to use tsmuxer to create an ISO from an MVC mkv of the 3D version, created with makemkv, and the Atmos soundtrack from the Japanese 2D version.
The two versions are not exactly the same length, there is about 1s difference, so I have to check audio sync.
Also tsmuxer added some messages about duplicated frames in the Atmos track. Hopefully it is able to recognise the metadata.
When I tried to play the hybrid 3D Atmos ISO with TMT, it did display the picture in 3D and my AVR detected the Atmos track, so apparently it looked fine.
I'll try to watch the 3D Atmos movie over the next couple of days and I'll report if it works.
I have little interest in I, Frankenstein but I wanted to practice this by the time I got Gravity (I already own the 3UK D Bluray and have pre-ordered the US Diamond Atmos edition, which is expected to ship at the end of the month).
@blackssr:
In theory it should work. I have several Dune 3D Bases. I will try my method when I receive my copy of Atmos Gravity at months end. Have you tried to combine the two 3D Titanic discs into a single ISO? I have successfully combined the two Hobbit 3D extended editions into single ISOs using tsMuxeR and they worked perfectly on my Dunes. Titanic is always out of sync on the second half. I believe it has to do with the brief "Insert Disc 2" message at the end of the first disc. It throws off the sync on the second. The Hobbit films do not have this.
Premium Member
I didn't try either the Hobbit or Titanic (I have both and don't really mind the changing of the disc).
I'll try again with Gravity at the end of the month, but I think the issue might be Atmos. I'm not sure the current version of tsmuxer is fully compatible with it, hence the many messages it displays during the process. If I try to mux the hybrid MVC version I had made, it doesn't recognise the Atmos track. I have to add it directly from the disc or ISO. maybe it has problems dealing with 3D and Atmos at the same time.
Again it might be an issue with the PC Players, I haven't been able to try with a 3D enabled mediaplayer.
Anyway, if it doesn't work, you know what to try. :).
i'll report about the sunc in I, Frankenstein when I have a chance to watch the movie, and of course about Gravity at the end of the month.
Did you use the same method above to combine the Hobbit?
Yes I did, But the Hobbit movies do not have that 7 second clip in them. I believe that clip is video only. When I combine the two parts that clip adds length to the video portion only so the audio on part 2 is now out of sync. I tried numerous times, each with different methods and still no luck. Each attempt takes about an hour. I was hoping someone on here with more experience and knowledge could shed some light on what the issue is.
Premium Member
Just to confirm that the audio sync was perfect in my I, Frankenstein hybrid 3D+Atmos.
I hope we'll get the same result with Gravity.
By the way it's only playable by the standalone TMT. The MCE plugin can't play the ISO. PDVD can't play it at all (standalone or MCE plugin).
What procedure did you use to do the conversion?
Good job!!
1 - 20 of 138 Posts
