Status
Not open for further replies.
1 - 4 of 4 Posts
I just vacuum occasionally.
Premium Member
If your grill cloths are stained or are very dirty, you can gently clean them by putting the grill cloth face down (outside face down) onto a cotton towel. From the back side, use a mild cleaner and a spray bottle and lightly clean the area, pressing down from the back side of the grill cloth onto the cotton towel. Make sure you do a spot test first to make sure if you're using a cleaner that it won't affect the cloth or the color.
I had to do this once when my dog was puppy and thought one of my speakers was a nice place to put his mark. Luckily, it only hit the grill cloth and side of the speaker cabinet.
Premium Member
You can also get new grill cloth from sources like Part's express.
1 - 4 of 4 Posts
Status
