Where do I need to connect the ground wire of my ground block? Can I connect it to the neutral of my circuit breaker? What wire gauge should I use for this purpose?
Well, I live in a condo so I can do so much.
Originally Posted by kevindd992002 /forum/post/20916524
Hmmm, how can I make sure that my provider indeed grounded the main coax cable?
Originally Posted by kevindd992002 /forum/post/20916587
So to be sure can I just ground my ground block on the ground's socket? I'm worried about Ground Loops though.
Originally Posted by olyteddy /forum/post/20919771
Have you read any of the replies? NO. A groundblock is meant to be outdoors.![]()
But the thing is that I'm not sure if my cable company DID ground my coaxial cable from the outside. |
If the plant was not grounded, it would be the same if you removed the Neutral from your home.
Originally Posted by gregzoll /forum/post/0
You can't. That is up to them per FCC guidelines & other requirements. If the plant was not grounded, it would be the same if you removed the Neutral from your home. Things would release magic smoke, and a whole lot of other stuff would happen.
