Hope this is the right forum. Need help on grounding a rooftop tv antenna and couldn't find forum close!
The basics are: want to install a HD tv antenna, tripod mount on the roof! The only ground I know of is the main electrical panel ground at the other end of the house. To add to this, the cable has to enter the house at the mid point of the house before splitting to 3 tv's. I know the antenna has to be grounded and the cable needs to be grounded so am I going to have to install ground rods where the ground wire comes off the roof and another where the cable enters the house? And tie them into the main entrance ground? Is this what's called bonding? Water pipes can't be used because thet've been changed to plastic. Any help would be greatly appreciated! If this is the wrong forum, please redirect! Thanks!
