1 - 7 of 7 Posts
hello everyone
i bought asus g74sx gpu(gtx 560m 3gb vram) and recived it yesterday and since then i was trying to connect it via hdmi to my 3d hdtv(panasonic tc-46pgt24)and i couldnt get it work (no picture no aoudio)i've tried everything and nothing work so please any help well be apreciated here is more deatils:
1-i've tried 3 diffrent hdmi cables (didnt work)
2-tried to uninstall reinstall nvidia driver now iam on the last ver 280 (didnt work)
3-tried to swetch modes from (fn)+(f8)dual mode,hdmi mode and from the nividia controll i tried making the pansonic primary main display (didnt work)
4-installed new windows 7 64bit ver also (didnt work)
5-tried all hdmi ports on the panasonic (didnt working)
6-updated the panasonic firmware to the latest (didnt work)
7-updated the asus bios to the latest
and here is some facts :
1-all three hdmi cables working fine on the same panasonic tv when iam using my old toshiba gpu 310m
2- i tried to connect the asus via vga cable to the pansoinc and it worked so the problem only in hdmi connection
the werid thing is that i tried my asus gpu(560m) on a sony lcd 40in and it worked fine so i guess the hdmi port is fine
now i dont know what is the problem is the 560m hdmi port work on some tv and some are not compitable ?
plese help i dont know what else to do
Originally Posted by saeedkunna
hello everyone
Try changing your display resolution to 1024x768 or 1366x768 at 60hz
Discussion Starter · #3 ·
hi thanks for responding
it didnt work i've tried both and just like always laptop screen goes black and no signal in th tv !
werid thing is laptop recognize the panasonic tv (in invidia controll panel and playback devices)
Do you have Viera Link set to on or off? I know sometimes with certain tvs if it's set to on and the device doesn't support it there are issues.
Discussion Starter · #5 ·
it was set to on i turned it off but still no luck didnt work
Discussion Starter · #7 ·
Originally Posted by videoguy60467 /forum/post/20878024
One more idea... on some Computers, you need to cycle Fn + F8 or some other key combo, and wait a few seconds to enable the external video output. Have you done that?
yes its fn+f8 to swicth between external display and laptot display =laptop screen goes black but nothing on tv no picture no audio
i also did it from nvidia contrl panel which reconize my tv (panasonic 0)i've choose the panasonic to be primary display then lapto screen goes black but nothing on tv
1 - 7 of 7 Posts
