Hi folks
I have an H&K that ha been in my theater for about two years with no problems what so ever.
I turned it on yeasterday and there was no sound!
The receiver turns on and the lights are blue so I know that it is not in standby, along with all the front panel readings! I mean i can switch inputs, raise volume and all of the other stuff, but there is no sound!
I would think that someone here has had this problem and knows what to check on the inside of the unit, i mean is there a fuse or anything like that?
Let me thank you all for any help in advance
UPDATE: I just opened up the covers and checked all the connections and noticed that the fan inside won't turn on either....It looks as if the amplifier section does not power up...does anyone know where the fuses are on the boad,since it is pretty crampted in there and i cant find them as of yet!
Thank you
Martin
Thank you
Martin
